Viewing Remote Sessions › Web Message Viewer › Web MV Main Window › Areas of the Web MV Main Window › Menu Bar
Menu Bar
The following information describes the options that you can access from the menu bar of the Web MV main window.
- The File menu at the top left of the Web MV main window contains four options: Connect, Disconnect, Select Session(s), and Exit.
- The Edit menu contains two options:
- The Auto End menu allows you to display and set current table modes. If a table is in Auto End mode, it automatically scrolls to the last message received from the CA Automation Point server. By default, both the Action Messages and Normal Messages tables are placed:
- In Auto End mode, each time Web MV is launched.
- A new session is selected from the Session drop-down box in the Command area of the Web MV main window.
- The Options menu contains both configuration options that are used to customize messages and the ability to load or save the current configuration profile. For descriptions of these dialogs and the visual attributes that you can configure with them, see the section Configuring Visual Attributes in this chapter.
