Previous Topic: Web MV Main WindowNext Topic: Menu Bar
Areas of the Web MV Main Window
The Web MV main window consists of the following three areas:
Action Messages table
Displays action (highlighted) messages. You can delete messages from this table. However, the corresponding messages are not deleted from the Normal Messages table. This procedure allows you to view them from the Normal Messages table. Deleting a message from this Action table sends a DOM request for the selected message. The Action Messages table is located under the menu bar in the top portion of the Web MV main window.
Displays both action (highlighted) and normal (non-highlighted) messages. The Normal Messages table is directly underneath the Action Messages table.
Note: Web MV allows standard Java table controls and edit box handling. For example, you can alter the view size of the tables or independently resize the table columns.
Command area
Allows you to submit a session command to one or more of the selected sessions for which you have command execute permission. The command area portion of the window is located directly beneath the Normal Messages table, at the bottom of the window.
Permission to submit commands is granted to remote users on a session-by-session basis and is validated through the same CA Automation Point security as the Remote Viewer. If you submit a session command, it is sent to the Web MV Web Server service. This service sends it to the rules engine, where it waits in a queue to be processed.
For more information on CA Automation Point session level security, see the section Securing the Remote Viewer.
