You can use the Export Settings function to copy all configuration settings into an archive you specify. These site archives reside in the installUserDir\Export directory, which is created by CA Automation Point. The export can be completed without shutting down any CA Automation Point applications or services.
All files are compressed and stored in this archive. To create different configurations for use under various circumstances, specify different archive names. These archives become standby site settings that you can later import into your active site directory.
You can export configuration settings using Configuration Manager. Select Manage Site Files from the File menu from a rules file if Automation Point Desktop is running with administrator rights. You can also use the Windows command prompt window.
You can also transfer exported configuration settings from one CA Automation Point server to another CA Automation Point server where you can import them using the same Export/Import utility.
The imported configurations are displayed in the Standby Site Archives list of the utility dialog.
