Previous Topic: Configuring PPQsNext Topic: PPQSTAT.bat Program
Using the TCP/IP Transport
To use the TCP/IP transport:
  1. Enable the TCP/IP check box.
  2. List the CA Automation Point servers that are permitted to share access to locally created PPQs over the network.
If you configured PPQs to use the TCP/IP transport, it defaults to TCP port number 2000. This port is acceptable when it is not being used. When the port is used change the default to another available port.
Notes:
