Previous Topic: Issuing PPQ Commands from CA OPS/MVSNext Topic: Using the TCP/IP Transport
Configuring PPQs
If you installed Program-to-Program Queues (PPQs), you need to select the appropriate setting for PPQ transports from the list of available network transports on the Program-to-Program Queues dialog.
To configure PPQs
  1. 1. Open Configuration Manager.
  2. 2. Select Expert Interface, Infrastructure, Program-to-Program Queues.
    The Program-to-Program Queues dialog displays.
  3. 3. Click Enable use of PPQs.
PPQs use the system name as a unique identifier for this system in its network communications. By default, the PPQ system name is your computer name (shortened to eight characters). If your computer name is longer than eight characters, you should override the default and choose an eight-character name that is unique to all machines that will be running PPQs.
