Using AS/400 Manager › Managing Multiple AS/400 Systems › Setting Up AS/400 to Connect to Multiple Stand-alone Systems › Configuring AS/400 Manager When Connecting to Multiple Stand-alone Systems
To configure AS/400 Manager, run the configuration program AS4CFG, which updates the values in the AS400CFG.cmd file. Perform the following steps:
- From Configuration Manager, choose Expert Interface, Automation, AS/400 Manager.
- In the AS/400 Manager Configuration window, Click Insert.
- In the AS/400 Session Description window, supply values for the following fields:
- Session Name
The system's alert session name (for example, SYS2GET)
- Session Type
ALR
- Click Insert.
- In the AS/400 System Description window, specify the following:
- System Name
The name of the AS/400 system
- Terminal Name
The name of the session (for example, SYS2GET)
- Language Code
The appropriate language code. For more information, see Step 6 in the section Configuring AS/400 Manager in this chapter.
- Script File
The name of the script file you created
- Startup Status
RSTART
- Tag Names
An alias for the AS/400 system
- Click OK until you return to the AS/400 Manager Configuration window.
- Repeat steps 2 through 6 for the automation session.
Note: This time specify the automation session name (for example, SYS2AUT), choose a session type of AUT, and specify the name of the script file you created.
- Click Save to save the settings to the AS400CFG.cmd file.
