Previous Topic: Choosing a Method for Connecting to Multiple SystemsNext Topic: Setting Up AS/400 to Communicate with AS/400 Manager
Setting Up AS/400 to Connect to Multiple Stand-alone Systems
To set up AS/400 Manager to connect to multiple stand-alone systems, perform the following procedures.
Note: The procedures you follow here parallel the ones you use to install AS/400 Manager using the sample configuration procedure.
Repeat the steps in these procedures for each system that you want to add, using new session names, file names, short names, and so on for each system.
