Previous Topic: Setting Up AS/400 to Communicate with AS/400 ManagerNext Topic: Customizing CA Automation Point Files to Install AS/400 Manager When Connecting to Multiple Stand-alone Systems
Setting Up Your Workstation When Connecting to Multiple Stand-alone Systems
To set up a workstation to connect to multiple standalone systems, follow this procedure:
  1. Verify that TCP/IP is able to communicate with the AS/400 system. To do so, open an operating system command prompt window and type one of the following commands:
    PING hostname
    PING ip-address
  2. Configure two sessions to the AS/400 system. Save the sessions with the names you prefer (for example, SYS2GET and SYS2AUT). One is the alerts session, the other the automation session. Optionally, you can configure a manual session also. You may choose to define these sessions as connection type TN5250 or TN3270.
