Using AS/400 Manager › Managing Multiple AS/400 Systems › Choosing a Method for Connecting to Multiple Systems
To connect to more than one AS/400 system, use one of the following methods:
- Set up an AS/400 system as an alert primary focal point to which multiple AS/400 systems can route their alert messages.
For instructions, see the section Setting Up the Alert Function in AS/400 in this chapter.
Note: If you need to issue a system command to another AS/400 system, you must define an automated session for that system.
- Set up AS/400 Manager to process alert messages from multiple stand-alone AS/400 systems. In this case, you must set up AS/400 Manager to connect to each additional system. The procedures for this are described in the sections that follow.
