Managing Sessions Using CA Automation Point Windows › Window Menu Options › Changing the Size of a Window
When you change the font that a window uses to display text, the size of the window changes automatically to accommodate the larger or smaller text.
Note: All of the window text fonts are large enough to read easily.
CA Automation Point gives you several options for choosing fonts:
- Select the next larger font in one of these ways:
- Press the Ctrl+right arrow keys.
- Choose Increase Font from the Window menu.
- Select the next smaller font in one of these ways:
- Press the Ctrl+left arrow keys.
- Choose Decrease Font from the Window menu.
- You can choose a specific font by choosing Select Font from the Window menu. Select one of the fonts listed in the Choose Font dialog.
Note: You can use the AXCUTIL2 utilities program to select other default screen fonts.
