Closing a window does not eliminate that window's function, or stop the automation occurring in the window; it only removes the session from the desktop. You can reopen the window using the Jump to Window dialog. To remove a window's function, delete the session from the session definition set.
To close a window from the CA Automation Point desktop, select the window that you want to close, and then choose Close This Window from the Window menu.
