Previous Topic: Wizard InterfaceNext Topic: Notification Setup Wizard
Automation Setup Wizard
The Automation Setup Wizard guides you step-by-step through the configuration of the key components of an automation server. This setup wizard explains the relevance of each component to automation system operations, helping you determine whether a component is required for the automation needs of your site.
Examples of tasks that the Automation Setup Wizard lets you configure include:
Click Next on the Automation Setup Wizard to perform the next recommended task, and click Finish when you are through with your configuration.
