The following commands are ADDRESS VOX utility commands.
Lists all the TAPI devices that are installed under Windows.
Allows you to modify notification server settings.
Duplicates the message stream from CA Automation Point to another queue that is accessible through PPQs, local or remote.
Start and stop trace logging.
Causes the issuing REXX EXEC to enter a system sleep state.
Starts another REXX program.
Provides the version number and configuration information of the CA Automation Point notification services at your site
