Use the following commands for voice processing tasks.
Waits for an incoming telephone call on any available voice channel, any voice channel within a group, or a specific voice channel only.
Waits for an incoming telephone call (in the same way as the ANSWER command) and plays one or more prerecorded voice messages after answering.
Initiates a telephone call using an open, available voice channel.
Initiates a telephone call on an available voice channel and plays one or more prerecorded voice messages.
Clears the digit buffer of a voice channel or its call progress analysis (CPA) parameters.
Serializes I/O activity on a voice channel by marking an available channel as in-use. The calling REXX program then has exclusive access to the channel.
Identifies the physical voice channel number associated with a channel handle.
Retrieves tone digits-such as menu selections or access codes that a remote party enters from a telephone keypad in response to a voice prompt-from the digit buffer of a voice channel.
Returns a text string containing a group name and a list of all physical voice channel numbers associated with the group.
Returns the current status of a voice channel.
Retrieves the system names of all connected notification servers in a distributed environment.
Loads a voice file or voice word library index file into main memory for faster access.
Plays a prerecorded voice message through a specified voice channel.
Plays a prerecorded voice message through a specified voice channel, and then retrieves tone digits that the remote party enters from the telephone keypad.
Records a voice message from the remote party and stores it in a disk file.
Resets a voice channel marked as in-use by the GETCHANNEL command, making the channel available to other REXX programs issuing a GETCHANNEL command. Used with the GETCHANNEL command to serialize I/O activity on a channel.
Sends tone digits through an already-open voice channel, useful for sending additional tones after CA Automation Point has successfully called and connected to the remote party.
Associates a group name with one or more voice channels.
Sets the hook state of a voice channel to on-hook or off-hook, useful in special circumstances such as multiple CALL operations within a single REXX program.
Adjusts the volume for current and subsequent PLAY operations on a specified voice channel.
Terminates an active I/O operation on a voice channel.
Checks the validity of the user ID and password combination of the remote party.
Sends a brief "handshaking" protocol signal through a voice channel.
