Previous Topic: Active LayoutNext Topic: Understanding Function Windows
Remote Viewer Layouts
You can save your currently active user interface layout and restore it later as needed.
For general information about layouts, see the section Layouts.
In Remote Viewer, a layout also contains connection information: which session on which host belongs to a specific window. When you load a layout in Remote Viewer, the application tries to restore the connection to the Automation Point Desktop that was connected at the time the layout was saved. Loading an empty layout closes all currently open connections.
Remote Viewer layouts are separate from Automation Point Desktop layouts; if you use both applications on the same machine, they cannot share layouts.
Security Notes:
