The CA Automation Point function windows let you monitor and control CA Automation Point processing. CA Automation Point provides the function windows listed in the following table:
Function Window |
Purpose |
Command |
Lets you issue commands to sessions that CA Automation Point manages. Some CA Automation Point function windows also have command areas which function like the Command window. |
Merged Msg |
Displays the messages that CA Automation Point collects from the sessions it manages and upon which CA Automation Point rules act. This window contains a command area and areas displaying the most recently issued action and normal messages. |
Action Msg Recall |
Displays the last 500 lines of outstanding action message text—messages waiting for an operator's response—received from sessions that CA Automation Point monitors. An action message is a message that requires a response from CA Automation Point or, in this window, from an operator. |
AP Msg |
Displays 20 lines of the most recently issued CA Automation Point messages. This window contains a command area. |
AP Msg Recall |
Displays the last 500 lines of message text that CA Automation Point issued. |
Normal Msg Recall |
Displays the last 500 lines of non-highlighted message text that CA Automation Point received from the sessions it monitors. |
AP Log |
Displays the contents of the current message log file. |
Host Log |
Displays the contents of the current host message log file. |
Plot |
Displays information about system operations shown as bar or line graphs. Create these graphs using the CA Automation Point Plot feature. |
AP Notification Messages |
Displays the last 500 messages generated by the notification server, notification (NMFIND) request, or Answer Tree application. |
CA OPS/MVS Messages |
Displays WTO messages generated by CA OPS/MVS. |
Each of the CA Automation Point function windows is optional, except for the AP Msg Recall window, which always displays. You can configure CA Automation Point to display only the function windows that you want to see.
