Using AS/400 Manager › Installing and Configuring AS/400 Manager › Configuring AS/400 Manager
To configure AS/400 Manager, you must run the configuration program AS4CFG. The program updates the values in the AS400CFG.cmd file. Initially, the configuration program supplies defaults that define a single local AS/400 system.
To run the AS4CFG program
- From Configuration Manager, choose Expert Interface, Automation, AS/400 Manager.
- In the AS/400 Manager Configuration window, select the AS400AUT session name, and then Click Change.
- In the AS/400 Session Description window, select the system name S44A0060, and then Click Change.
- In the AS/400 System Description (AS400AUT) window, under System Name, change the system name to the name of your system.
- Select the tag name S44, Click Change, and then enter a tag (alias) name for your system.
- Select the appropriate language code. If the title of the AS/400 WRKALR panel is displayed in English uppercase characters (for example, WORK WITH ALERTS), change the language code for the session from ENG to ENU.
- Click OK until you return to the AS/400 Manager Configuration window.
- Repeat Steps 1 through 6 for the remaining default session name, AS400GET.
Note: The default tag name is A44. Change it to a tag name for your system.
- Click Save to save the settings to the AS400CFG.cmd file.
To configure AS/400 in a multiple AS/400 system configuration, see the section Configuring AS/400 Manager When Connecting to Multiple Stand-alone Systems in this chapter.
