You need to insert configuration information for AS/400 Manager into your CA Automation Point files.
To insert configuration information for AS/400 Manager into your CA Automation Point files
Add the AS/400 Manager rules to your CA Automation Point rules file, AXCRULES.RUL. If you have rules you want to keep, use an editor to merge the AS400RUL.rul contents into your current AXCRULES.RUL file. Everywhere you see the system name of S44A0060, change it to your actual system name.
For each session:
a. Set Communication Device to "MEMORY."
b. Set Parity to "Ignore."
c. Set CR/LF Interpretation to "Yes".
Customize the CA Automation Point script, AS400GET.SCR, which is the sign-on/recovery script for the alert session.
Edit the AS400GET.SCR file. On the line "KEY=(userid@Tpassword@E)" substitute "userid" with the user ID you want to log on to. If your AS/400 system requires a password, substitute "password" with the correct password as well. If no password is required, delete the following text, which represents a TAB keystroke and the password:
@Tpassword
Do not delete the text "@E," which represents a carriage return.
If the AS/400 system is using a non-English language or customized log-on screen, you may need to customize the search text in this file.
To customize CA Automation Point files in a multiple AS/400 system configuration, see the section Customizing CA Automation Point Files to Install AS/400 Manager When Connecting to Multiple Stand-alone Systems in this chapter.
