The following sample REXX code illustrates a sample inbound status application:
/* REXX */
ChannelInUse = 'N' /* Channel not obtained yet */
Terminate = 'N'
/* Setup Error Handler in event program encounters Ctrl-Break */
SIGNAL ON HALT NAME DOEXIT
Call GetFreeChannel
Do While (Terminate <> 'Y')
Call WaitForACall
If (result <> 0) Then
Terminate = 'Y'
Else
Do
Call UserApplication
Terminate = 'Y'
End
End
Call ReleaseTheChannel
exit
GetFreeChannel:
/* Obtain an available voice channel */
/* Channel can be obtained by channel number */
/* or by Group, in this example, a Group of ALL */
/* is used...... */
Address VOX "GETCHANNEL Group(All) Prefix(Handle)"
If (rc <> 0) Then Do
say 'Unable to obtain an available channel. RC='rc
exit 16
End
ChannelInUse = 'Y' /* remember we now have a channel */
return
WaitForACall:
/* Waiting for a call on a specific channel before returning */
/* For improved performance, use VOX ANSWERPLAY */
/* since VOX message to be played is loaded into */
/* memory prior to making answering phone call. */
GreetingToPlay = 'greeting.vox getuserid.vox'
Address VOX "ANSWERPLAY Channel("Handle") ",
"File("GreetingToPlay") FILETYPE(NONINDEX)"
say 'Problem answering call RC='rc
return 16
End
/* Before returning to main line code, you may want to */
/* verify connecting caller, you can use VOX GETDIGITS,*/
/* PLAYGETDIGITS and VERIFYUSER commands... */
IdLen = 6 /* Assume Userid is length 6 */
PinLen = 6 /* Assume Pin # is length 6 */
Address VOX "GETDIGITS Channel("Handle") ",
"Count("IdLen") Prefix(CallerId)"
say 'Problem obtaining caller userid RC='rc
return 16
End
/* Get caller's pin number. */
Address VOX "PLAYGETDIGITS Channel("Handle") ",
"FILE(GetPin.Vox) FILETYPE(NONINDEX)",
"Count("PinLen") Prefix(CallerPin)"
say 'Problem obtaining caller pin number RC='rc
return 16
End
/* Verify the connected phone call */
Address VOX "VERIFYUSER Userid("CallerId") Pin("CallerPin")"
say 'Unable to Verify Caller RC='rc
return 16
End
/* Caller is OK, now we can return to main line */
return 0
UserApplication:
/* User specific application can go here */
/* Can use VOX PLAY command to play */
/* stock quotes, system status etc., */
/* Make sure phone is back on hook before returning to mainline */
Address VOX "SETHOOK Channel("Handle") HOOKSTATE(ONHOOK)"
say 'Unable to put phone back onhook RC = 'rc
return 16
End
return 0
ReleaseTheChannel:
/* Release the channel obtained, this is done */
/* by calling VOX RELEASECHANNEL command */
If (ChannelInUse = 'Y') Then Do
Address VOX "RELEASECHANNEL Channel("Handle")
say 'Unable to release channel RC='rc
End
Else
ChannelInUse = 'N'
End
return
DoExit:
/* Perform any necessary cleanup such as releasing the */
/* channel by calling VOX RELEASECHANNEL command */
/* perform other application specific cleanup */
/* terminate application */
exit
return
