Using Notification Services › Example VOX Environment Applications
This section presents REXX programs that employ voice commands. The programs illustrate the following application types:
- Outbound voice notification with input from caller
- Outbound recording and voice message delivery
- Inbound application with input from caller
Although the REXX code shown may vary slightly from the code on your distribution media, you can use the examples as a basis for writing your own voice processing applications.
Each example REXX program is presented in the same format. Each example contains these elements in the order listed:
- A statement of the program's purpose, indicating what the program does and the primary operations that it illustrates
- A listing of the ADDRESS VOX commands used in the code
- A listing of the REXX source code
- A description of how the program works
