Previous Topic: Notification Server OptionsNext Topic: Installing the Dialogic Voice Card
VOX Client Options
The VOX client must be installed on any machine that runs Notification Manager or for any REXX programs that issue ADDRESS VOX commands.
Note: The VOX client is automatically enabled if the notification server is enabled.
To configure VOX client options
  1. Open Configuration Manager
  2. Choose Expert Interface, Notification Services, Notification Services Startup Options.
    The Notification Services Startup Options dialog displays.
    The VOX Client area of the dialog controls the startup options for the VOX client. This group is disabled if the VOX client has not been installed on this workstation.
  3. Check Enable Client.
    You can now use the notification server on this workstation.
Note: For information about the other fields in this dialog, see the dialog help.
