Using Notification Services › Configuring Notification Services › Notification Server Options
To configure notification server options
- Open Configuration Manager.
- Choose Expert Interface, Notification Services, Notification Services Startup Options. The Notification Services Startup Options dialog displays. The Notification Server area of the dialog controls the startup options for the notification server. (This area is disabled if the notification server has not been installed on this workstation.)
- Check Enable Server.
You can now use the notification server on this workstation.
Note: For information about the other fields in this dialog, use the dialog help.
