Previous Topic: Submitting Commands with ALLNext Topic: Configuring Visual Attributes
Messages Columns
The Web MV main window displays messages in two tables, the Action Messages table and the Normal Messages table. Each table displays one line for each message that is received. Each line is then separated into columns of information for that message.
The information found in the columns for each message is displayed in the following table:
Column Name
Information Displayed
Session
Name of the CA Automation Point session from which the message was captured
System
Processor ID of the host system (if available), or host system name as defined in the CA Automation Point session definition (SYSNAME)
Date
Current system date on the CA Automation Point server
Time
Current system time on the CA Automation Point server
Host Time
Time at which a message was received from the host (if available)
Job ID*
Current JES job ID associated with the message
Job Name*
Job name of the address space that issued the message
EMS Date*
Date contained in first eight characters of a TANDEM EMS message
JES3 Name*
System name of a JES3GLOBAL or sysplex console
MON Name*
Source system name for a DataFrame message
MON Num*
Source system number for a DataFrame message
MON Prty*
Priority of the alert message issued by the DataFrame system
MON Type*
Type of alert message issued by the DataFrame system
Act Ind*
Character used to denote action messages on the host system (for action messages only)
Msg Num
ID of the message (assigned by CA Automation Point)
Seq Num
Sequence ID of the message (assigned by CA Automation Point)
Note: This number is greater than zero for multi-line messages.
Message
Text of the message
Reply ID*
Reply number for a message that is a WTOR
Sess Type
Type of session as defined by the Console Type control on the Session Definition window
Act Msg
Specifies whether this message is currently an action message (in Y/N format)
* These columns may not contain data, depending upon the type of message.
For information on how to choose the columns you want to display, see the section Specifying Table Columns for Your Messages in this chapter.
