Viewing Remote Sessions › Web Message Viewer › The Built-in ALL Option › Viewing Messages with ALL › Submitting Commands with ALL
The ALL option also allows you to issue a single command to more than one session. To issue the specified command to more than one session, select ALL from the session drop-down list, type the session command in the command area, and then click Submit Cmd.
The Multiple Session Selection dialog displays, allowing you to choose which sessions will receive the session command that you have specified.
Notes:
- Every time you select the ALL option, and you want to issue a session command, the Multiple Session Selection dialog displays, allowing you to choose which sessions will receive the session command that you have specified.
- Depending on your Web MV security configuration, the Target sessions for command list may not be the same as the list in the session drop-down list in the Session and Command area of the Web MV main window. Consequently, you may be able to view certain sessions, but be unable to issue commands for them.
For more information about the fields in the Multiple Session Selection dialog, see the Web Message Viewer HTML Help.
