Previous Topic: Looking at the Keyboard Parameter FilesNext Topic: Key Operations Specific to CA Automation Point
Keys Mapped to Terminal Operations
The following table displays the keys mapped to terminal operations:
Operation
What It Does
Enhanced 101-keys Mapped to Operation
0 to 9
Types the indicated number (from 0 to 9) on the host screen
0 to 9
A to Z
Types the indicated uppercase letter (from A to Z) on the host screen
A to Z
a to z
Types the indicated lowercase character (from a to z) on the host screen
a to z
ATTN
Issues an attention to the terminal
Shift+Esc
BACK_QUOTE
Types an accent grave (backward quote) character on the host screen
BACK_SLASH
Types a back slash (\) on the host screen
BACK_SPACE
For a terminal emulator window, moves the cursor one space left
Back
BACK_TAB
Moves the cursor backwards one position
Shift+Tab
CLEAR
Clears the current screen of text
Keypad+Minus
COMMA
Types a comma on the host screen
CURSOR_BLINK
Turns blinking cursor on or off
User-definable
CURSOR_SEL
Changes the cursor from a block to an underline character or, conversely, from an underline character to a block
Scroll Lock
DEV_CNCL
Issues a DEV_CNCL instruction
User-definable
DOUBLE_QUOTE
Types double quotation marks on the host screen
DOWN
Moves cursor down one line
Down arrow
DUP
Issues a DUP instruction
101E+Shift+Insert
END
Moves cursor to the bottom left corner of the screen
End
ENTER
Issues a carriage return
Enter
EQUAL
Types an equal sign on the host screen
ERASE_EOF
Erases all characters immediately following the cursor on this screen field
101E+End
ERASE_INPUT
Erases all unprotected fields on the host screen
101E+Alt+End
FAST_LEFT
Moves cursor two spaces to the left
101E+Alt+Left
FAST_RIGHT
Moves cursor two spaces to the right
101E+Alt+Right
FIELD_EXIT
Issues "Field Exit" to the iSeries console (5250 only)
Alt+E
FM
Issues a field mark instruction
101E+Shift+Home
HAT
Types the not equal character (¬ on the host screen
Note: Your workstation screen displays the ^ character.
Shift+6
HOME
Moves cursor to the first unprotected field on the host screen
Home
IDENT
Issues an IDENT instruction
User-definable
INS
Turns insert mode on
Insert
LEFT
Moves cursor left one character position
Left arrow
LEFT_BRACKET
Types the vertical bar character (|) on the host screen
Note: Your workstation screen displays the [ character.
LEFT_PAREN
Types a left parenthesis on the host screen
LINE_INS
Issues a Line Insert instruction
User-definable
LINE_DEL
Issues a Line Delete instruction
User-definable
MODE_SEL
Switches between a hardware console and software console session on an CA Automation Point terminal emulator
User-definable
NEWLINE
Line feed; moves cursor to the next line (3270 only)
Ctrl+Enter
PA1
Invokes the command assigned to the PA1 key
101E+Page Up
PA2
Invokes the command assigned to the PA2 key
101E+Page Down
PA3
Invokes the command assigned to the PA3 key
101E+Shift+Page Down
PF1 to PF9
Invokes the command assigned to the indicated PF key
F1 to F9
PF10
Invokes the command assigned to the PF10 key
F10
PF11
Invokes the command assigned to the PF11 key
F11
PF12
Invokes the command assigned to the PF12 key
F12
PF13 to PF24
Shift+F1 to Shift+F12
PF26 to PF36
User-definable
Pgdn
Moves the cursor down one full page
Page Down
PGDN
Issues a Page Down to the iSeries cosole (5250 only)
PgDn
PgUp
Moves the cursor up one full page
Page Up
PGUP
Issues a Page Up to the iSeries cosole (5250 only)
PgUp
POWER_RESET
Sends a reset-terminal instruction to the controller
Ctrl+Page Down
RESET
Issues a RESET instruction
Esc
RIGHT
Moves cursor right one character position
Right Arrow
RIGHT_BRACKET
Types a cent-sign character (¢) on the host screen
Note: Your workstation screen displays the ] character.
RIGHT_PAREN
Types a right parenthesis on the host screen
SINGLE_QUOTE
Types a single quotation mark character (') on the host screen
SPACE
Types a blank space on the host screen
Space bar
SPLIT_BAR
Types a splitbar character (|) on the host screen
START
Starts up a mainframe system connected to the workstation through a terminal emulator
User-definable
STOP
Shuts down a mainframe system connected to the workstation through a terminal emulator
User-definable
SYS_REQ
Issues a SYS_REQ instruction
Alt+F1
TAB
Moves cursor forward one tab position
Tab
TEST
Issues a TEST instruction
Alt+F8
UNDER
Types the underline character on the host screen
_
UP
Moves the cursor up one line
Uparrow
Types an exclamation point on the host screen
Types a pound sign on the host screen
Types a dollar sign on the host screen
Types a percent sign on the host screen
Types an ampersand on the host screen
Types an asterisk on the host screen
Types a plus sign on the host screen
Types a minus sign on the host screen
Types a period on the host screen
Types a slash on the host screen
Types a colon on the host screen
Types a semicolon on the host screen
Types a question mark on the host screen
Types an at sign on the host screen
Types a left brace on the host screen
Types a right brace on the host screen
Types a vertical bar on the host screen
Types a tilde on the host screen
3270_ASSIGN
Issues an ASSIGN instruction
User-definable
3270_CANCEL
Issues a CANCEL instruction
User-definable
3270_IRPT
Issues an IRPT instruction
User-definable
3270_ISTEP
Issues an ISTEP instruction
User-definable
3270_PLAY
Issues a PLAY instruction
User-definable
3270_RECORD
Issues a RECORD instruction
User-definable
3270_RESTART
Issues a RESTART instruction
User-definable
3270_RULE
Issues a RULE instruction
User-definable
3270_SETUP
Issues a SETUP instruction
User-definable
3270_SVPCE
Issues an SVPCE instruction
User-definable
3270_SWAP
Issues a SWAP instruction
User-definable
3270_TOD
Issues a TOD instruction
User-definable
3270_1 to 3270_25
User-defined
User-definable
6530_ROLL_UP
Issues a Roll Up instruction (6530 only)
User-definable
6530_SROLL-UP
Issues a Shifted Roll Up instruction (6530 only)
User-definable
6530_ROLL_DOWN
Issues a Roll Down instruction (6530 only)
User-definable
6530_SROLL_DOWN
Issues a Shifted Roll Down instruction (6530 only)
User-definable
6530_NEXT_PAGE
Issues a Next Page instruction (6530 only)
User-definable
6530_SNEXT_PAGE
Issues a Shifted Next Page instruction (6530 only)
User-definable
6530_PREV_PAGE
Issues a Prev Page instruction (6530 only)
User-definable
6530_SPREV_PAGE
Issues a Shifted Prev Page instruction (6530 only)
User-definable
6530_RETURN
Issues a Return instruction (6530 only)
User-definable
6530_SRETURN
Issues a Shifted Return instruction (6530 only)
User-definable
