The key_101.key file defines the Enhanced 101-key keyboard. Each line in the keyboard parameter file defines a single key. This key definition consists of two required parameters and the MAP parameter, which is optional. The following list briefly describes these parameters. See the Command and Keyword Reference Guide for details about parameter syntax.
Specifies the operation being defined (for example, A, PF1, QUIT)
Specifies the location of the key on the keyboard
Specifies the types of windows in which this operation applies. By default, the operation applies to both function and terminal emulator windows.
Use the key maps that follow as references for your keyboard. If you have customized one of the files, indicate any changes in the margins.
Press the Alt key and the specified key at the same time.
Press the Ctrl key and the specified key at the same time.
Use the keys on your workstation keypad.
Press a shift (left or right Shift or Caps Lock) key and the specified key at the same time.
Use the extra keys on the Enhanced 101-key keyboard.
