The following sample screens show a dialog initiated by AS400CTL:
Work with Alerts S44A0060 Type options, press Enter. 2=Change 4=Delete 5=Display recommended actions 6=Print details 8=Display alert detail 9=Work with problem Resource Opt Name Type Date Time Alert Description: Probable Cause 8 S44A0060 CP 03-30 10:45 Undetermined error: Undetermined Bottom F3=Exit F10=Show new alerts F11=Display user/group F12=Cancel F13=Change attributes F20=Right F21=Automatic refresh F24=More keys
Display Alert Detail S44A0060
----------Resource Hierarchy----------- Resource Name Resource Type S44A0060 CP Logged date/time . . . . . . : 93-03-30 10:45:51 Problem date/time . . . . . : 93-03-30 10:45:50 User assigned . . . . . . . : Group assigned . . . . . . . : Alert type . . . . . . . . . : Unknown Alert description . . . . . : Undetermined error Probable cause . . . . . . . : Undetermined Qualifiers . . . . . . . . . : AS/400 Message code CPA5305 AS/400 Message severity 99 More... Press Enter to continue. F3=Exit F11=Display detail menu F12=Cancel F18=Display actions
Work with Alerts S44A0060 Type options, press Enter. 2=Change 4=Delete 5=Display recommended actions 6=Print details 8=Display alert detail 9=Work with problem Resource Opt Name Type Date Time Alert Description: Probable Cause 4 S44A0060 CP 03-30 10:45 Undetermined error: Undetermined Bottom F3=Exit F10=Show new alerts F11=Display user/group F12=Cancel F13=Change attributes F20=Right F21=Automatic refresh F24=More keys
Display Alert Detail S44A0060 ----------Resource Hierarchy----------- Resource Name Resource Type S44A0060 CP Text message: Sender ID . . . . . . : Control program Message . . . . . . . : Record not added. Member MEMBERNAME is null. (C I) Unique alert identifier: Product ID . . . . . . : 9406 Alert ID number . . . : 331A A4A1 Bottom Press Enter to continue. F3=Exit F11=Display detail menu F12=Cancel F18=Display actions
Confirm Delete of Alerts S44A0060 Press Enter to confirm your choices for 4=Delete. Press F12 to return to change your choices. Resource Opt Name Type Date Time Alert Description: Probable Cause 4 S44A0060 CP 03-30 10:45 Undetermined error: Undetermined Bottom F11=Display user/group F12=Cancel F20=Right
Work with Alerts S44A0060 Type options, press Enter. 2=Change 4=Delete 5=Display recommended actions 6=Print details 8=Display alert detail 9=Work with problem Resource Opt Name Type Date Time Alert Description: Probable Cause (No alert entries matching selection criteria) Bottom F3=Exit F10=Show new alerts F11=Display user/group F12=Cancel F13=Change attributes F20=Right F21=Automatic refresh F24=More keys
