The following table lists the REXX programs supplied with AS/400 Manager, what the application is called by, and what the program does after it is called.
This REXX program... |
Called by... |
Does this... |
AS400CKJ.cmd |
User-written automation program |
Illustrates how to implement a program to perform an automatic action |
AS400CMD.cmd |
Rule that implements SYSCMD application |
Issues OS/400 operator line mode commands |
AS400CTL.cmd |
The configuration program AS400SET at startup, or restarted by a rule if AS400CTL fails |
Captures alerts from AS/400 systems in RSTART status, converts them to CA Automation Point messages, and sends them to rules |
AS400INI.cmd |
AS400JMP with the session and system names |
Runs a session sign on program |
AS400JMP.cmd |
AS400MRP and from user-written automation REXX programs |
Checks the system status, and then binds to the session |
AS400MRP.cmd |
User-written rules |
Performs message reply to AS/400 |
AS400REC.cmd |
Rules invoked when a system is in FAILED status |
Performs recovery on failed communications with system |
AS400SET.cmd |
IREXX at CA Automation Point startup |
Calls AS400CFG.cmd to initialize the AS/400 configuration; starts AS400CTL.CMD for each alert session defined |
AS400SLR.cmd |
User-written automation programs and from AS400MRP |
Invokes a session error program |
AS400SPN.cmd |
Rules |
Implements the SUSPEND RESUME application commands |
AS400SSD.cmd |
Time rules when the system status has changed |
Plots the system status in the AS400SSD plot window for all defined sessions |
AS400STA.cmd |
Rule that implements the DSPSTAT application command |
Displays AS/400 system status information in the AP Msg window |
AS400SUS.cmd |
Time rules |
Manages suspend time for systems in SUSPND status and decrements the suspension timer value. When the suspend interval has elapsed, it sets the system status to RSTART. |
AS400SYS.cmd |
Rule that implements the DSPCNFG application command |
Displays a list of configuration definition status variables in the AP Msg window |
AS400VRY.cmd |
