Viewing Remote Sessions › Web Message Viewer › Web MV Main Window › Areas of the Web MV Main Window › Menu Bar
Menu Bar
The following information describes the options you can access from the menu bar of the Web MV main window.
- The File menu at the top left of the Web MV main window contains three options: Connect, Disconnect, and Exit.
- The Edit menu contains two options:
- The Auto End menu allows you to display and set current table modes. If a table is in Auto End mode, it automatically scrolls to the last message received from the CA Automation Point server. By default, both the Action Messages and Normal Messages tables are placed in Auto End mode each time Web MV is launched or a new session is selected from the Session drop-down box in the Command area of the Web MV main window.
- The Options menu contains configuration options used to customize messages. From this menu, you can access the Visual Attributes dialogs. For descriptions of these dialogs and the visual attributes that you can configure with them, see the section Configuring Visual Attributes in this chapter.
