The Web MV main window consists of the following three areas:
Displays action (highlighted) messages. You can delete messages from this table. If you do, the corresponding messages will not be deleted from the Normal Messages table, so you will still be able to view them from there. Deleting a message from this Action table sends a CA Automation Point DOM request for the selected message. The Action Messages table is located under the menu bar in the top portion of the Web MV main window.
Displays both action (highlighted) and normal (non-highlighted) messages. The Normal Messages table is directly underneath the Action Messages table.
Note: Web MV allows standard Java table controls and edit box handling; for example, you can alter the view size of the tables or independently resize the table columns.
Allows you to either submit a session command to the current session or change the currently monitored session. The command area portion of the window is located directly beneath the Normal Messages table, at the very bottom of the window.
Permission to submit commands is granted to remote users on a session-by-session basis and is validated through the same CA Automation Point security as the Remote Viewer. If you submit a session command, it is sent to the Web MV Web Server service, which sends it to the CA Automation Point engine, where it waits in queue to be processed.
Note: You can submit a specified command to more than one session by selecting ALL from the session drop-down list. The ALL option allows you to issue a command to one or more of the sessions for which you have command execute permission. For more information about using the ALL option, see the section The Built-in ALL Option in this chapter.
For more information on CA Automation Point session level security, see the section Securing the Remote Viewer in this chapter.
