Previous Topic: How You Switch Asynchronous Signals with a Null ModemNext Topic: Asynchronous Communication Problems
How You Test Asynchronous Communications
Start CA Automation Point and jump to the session that you have just defined to verify that CA Automation Point can communicate with the host. If everything is working properly, you should see Cn=R or Dn=R (with n equal to a number from 1 to 8) in the status line of the session window.
Note: For more information about the status line, see the section The Status Line in this chapter.
