Previous Topic: Using Serial COM PortsNext Topic: How You Test Asynchronous Communications
How You Switch Asynchronous Signals with a Null Modem
To achieve acceptable asynchronous signal conditions, you may need to install a device known as a null modem. Most asynchronous devices communicate using a wiring protocol called RS-232. One side of a connection is called the data terminal and the other side is called the data set. As long as your host device is wired as a data set and the COM ports are wired as data terminals, there should be no communication problems. However, if the host you are connecting to is wired as a data terminal, mismatching signals will result. Consequently, you need to insert a null modem. Use the following components to establish this type of connection:
Note: When RS-232 signals are mixed up, one-way communication results.
