Install the Multi-Port Monitor software using the CD that is provided in the shipping carton with the appliance. The Multi-Port Monitor software must match the the prerequisites file that is already installed on the appliance.
After the installation, we recommend that you visit the Download Center on CA Support to verify that you have the latest software version. If necessary, upgrade the Multi-Port Monitor to the latest version.
Important: The CentOS operating system is installed on the appliance. Do not install additional operating system software.
The initial Linux screen opens.
Multi-Port Monitor verifies that the password meets the security requirements. Hints are provided for passwords that are too simple.
Note: If the following message appears, you supplied too many rejected passwords. The operating system opens the Linux login screen. Return to step 2.
"Authentication token manipulation error"
When the login is successful, the Linux command-line interface opens.
ls /misc/cd
sudo mkdir /mnt/cd sudo mount -t auto /dev/dvd /mnt/cd ls /mnt/cd
sudo /usr/bin/php /misc/cd/setup-mtp
sudo /usr/bin/php /mnt/cd/setup-mtp
The Select Time Zone screen opens.
Note: If the date and time are correct in the fields, do not retype the information.
The setup script untars the archive containing the executable and performs other configuration tasks. Software is installed to the /opt folder. When the setup completes, a confirmation message appears.
sudo umount /misc/cd
sudo umount /mnt/cd
eject /dev/dvd
sudo reboot
The appliance restarts and is ready for the configuration of network access.
