Understanding the Data in the Display Area › Types of Data › Add or Remove Columns in a Data Table
By default, some data is excluded from the data table on the Traffic and TCP tabs. You can include more columns of data.
- Click Edit Columns.
The Edit Columns dialog opens.
- Select the check boxes for the metrics you want to add to the data table.
- Clear the check boxes for the metrics you want to remove from the data table.
- Click Default to restore default column settings.
- Click Save.
Your changes are reflected in the data table after it refreshes.
