The data table consists of two tabbed views that provide different perspectives on captured data from the same time frame. Each view provides different metrics and applies filters in different ways.
The TCP tab contains data specific to TCP-based applications and metrics for CA Application Delivery Analysis reports. The tab also contains performance metrics that are calculated from the captured packets. The label on the Name column changes to indicate whether clients or servers are displayed.
Note: The TCP tab is selected by default when you drill down from CA Application Delivery Analysis. In general, the format of the data on the TCP tab closely resembles the format of data in CA Application Delivery Analysis reports.
The Traffic tab contains all other available data, not restricted to TCP applications. The Traffic tab does not apply a concept of client or server. Therefore, the Name column can show the names of both clients and servers, depending on the selected view. The Traffic tab also includes non-TCP traffic, which can result in the inclusion of more hosts.
The names of some performance metrics are abbreviated in the data table to reduce the width of the table. To see the full name of a metric, position the mouse pointer over the abbreviated column name or its check box. The flyover text provides the full name of the selected metric.
