You can change a global filter to restrict the data included in an analysis.
Note: If you change the Logical Ports global filter, you effectively change the entire dataset for the selected analysis.
The Global Filters dialog opens.
The tab displays a list of all known applications whose traffic is reflected in the captured packets from the time frame you are viewing.
The selected application appears as Currently Selected. The application port number appears in parentheses. The selected application also filters the lists of items on the other tabs in the Global Filters dialog.
For example, click the Server tab. Only servers that are running the selected application (SMTP, in this example) are shown in the list. Select a server.
The chart and table for the current analysis are filtered to show only data from the SMTP application and its application servers.
