Previous Topic: Data ViewsNext Topic: View the Current Filter Conditions
Using Filters to Customize Data in the Display Area
Multi-Port Monitor offers several methods for narrowing the scope of session-level metrics shown in the Display area of the Analysis page. The following options can be applied to the data displayed from a selected analysis.
Data views
You can select different data views to focus on the network aspect that makes the most sense for the current troubleshooting task. For example, if an application has slow response time, select the Server IP view or the Application view to see the associated metrics.
Use analysis filters to filter the data in a view.
Note: Analysis filters are distinct from the Hardware filters you apply to captured data. Hardware filters affect the capture of data. Analysis filters affect the display of data.
Context-specific filtering
Drill-down filtering
Zoom filtering
Line graphs provide more filtering options. The Zoom In and Zoom Out links let you focus more closely on the performance metrics from a smaller segment of captured data.
Time frame filtering
The Summary Trend chart, Line Trend chart, and Stacked Trend chart formats include a time-navigation component above the Display area. The default time frame is 15 minutes. The Time Period Selector enables precise selection of another time frame.
This section contains the following topics:
Analysis Filters
Global Filters
