Previous Topic: newNext Topic: set
clean
The clean command is used to disable and uninstall a grid.
Important: The clean command destroys all data on a grid. The command prompts for confirmation. Use the aldo clean command only to de-commission a grid from which all valuable data has been saved.
aldo clean grid=name [ controller_ip= ] [ controller_name= ]
grid=name
Name of the grid to destroy. Required.
controller_ip=ipaddr
Address of the grid controller. This value is not required if the grid was installed from the same distribution server on which the clean command is being run.
controller_name=host
DNS name of the grid controller. This value is not required if the grid was installed from the same distribution server on which the clean command is being run.
Examples:
Enter the command:
aldo clean grid=test1
Result: The command cleans grid test1.
Enter the command:
aldo clean grid=test2 controller_ip=10.64.64.64
Result: The command cleans grid test2 but with an explicit controller address specified. This format is a safer option as it works even if the configuration cache on the distribution server is not present.
