Reason:
The remotely-initiated task level within the CA XCOM Data Transport region has been analyzed and compared to the defined threshold. The remotely-initiated task level has exceeded the configured threshold value. This is an exception condition that can affect performance as stated above.
Action:
This message is issued by the CA XCOM Health Check exit, which provides detailed information about the exception condition and the suggested response. The following actions and responses are documented for this check:
The CA XCOM Data Transport region attempts to continue processing.
None required.
N/A
Either externally pace the workflow of transfer requests processed by the CA XCOM Data Transport server or, if sufficient system resources are available, adjust the maximum number of tasks allowed by increasing the MAXTASK parameter specified on the #DFLTAB macro used to generate the CA XCOM Default Options Table. The MAXTASK configuration value can also be immediately (but temporarily) changed using the CA XCOM Data Transport DFLT console command.
CA XCOM Data Transport module XCOMXFER
See the CA XCOM Data Transport for z/OS Administration Guide.
