Reason:
IBM_APAR_OA23740=NO was specified or defaulted in #DFLTAB. This exception only applies to CA XCOM Data Transport regions running on operating system levels below z/OS 1.10.
Action:
This message is issued by the CA XCOM Health Check exit, which examines the value of the IBM_APAR_OA23740 in the Default Options Table. The following actions and responses are documented for this check:
The system continues processing, but without the ability to transfer USS files.
None required.
Determine if IBM APAR OA23740 has been applied. If so, then change the value in the XCOM Defaults Table (#DFLTAB) to YES.
CA XCOM Data Transport module XCOMXFER
See the following guides:
