Previous Topic: 8015INext Topic: 9001E
8016I
RECORDS ON HISTORY FILE ON OR BEFORE yyddd WILL BE DELETED
Reason:
XCOMUTIL will delete all records that were written on or before Julian date yyddd.
Action:
None
8017E
DAYS ENTERED GREATER THAN THE NUMBER OF DAYS FOR THE SPECIFIED YEAR
Reason:
The day number specified in the Julian date is too large for the specified year. The value must not be greater than 365 for nonleap years, 366 for leap years.
Action:
Correct the Julian date specified for the DATE parameter and rerun XCOMUTIL.
8018E
INVALID RELEASE FOR MIGRATION SPECIFIED – MUST BE 11.5 or 11.6
Reason:
When running a history or request queue migration, the RELEASE= parameter does not contain a valid release to migrate the history file cluster or request file to.
Action:
Correct the RELEASE parameter to be 11.5 or 11.6 for XCOMUTIL or 11.6 for XCOMMIGR and rerun XCOMUTIL/XCOMMIGR. Specify 11.5 or 11.6 to perform backward migration of the VSAM History File cluster or specify 11.6 to perform backward migration for the request queue file. Specify 11.6 to perform forward migration of an 11.5 VSAM History File cluster or request queue file to the new version 11.6 format.
8019E
YYYYYY FILE XXXXXXXX NOT AT PROPER RELEASE LEVEL FOR MIGRATION
Reason:
When running a history migration, the source history file sequential data set does not contain the proper size history records for the migration selected.
When running a request queue migration, the source request queue file sequential data set does not contain the proper size queue records for the migration selected.
Action:
Correct the LRECL for the history/request queue file sequential data set created by the IDCAMS job to repro the history file cluster/request queue file. The proper size of the record is 2024 for 11.5, 3034 for 11.6 and rerun XCOMUTIL/XCOMMIGR.
8020E
MULTIPLE RELEASE PARAMETERS ENTERED
Reason:
Multiple RELEASE parameters were specified for the history/request queue file migration process.
Action:
Remove the extra RELEASE parameters and rerun XCOMUTIL/XCOMMIGR.
8021E
BACKWARD MIGRATION OF A REQUEST QUEUE TO 11.5 IS NOT SUPPORTED
Reason:
A request queue file cannot be migrated from version 12.0 to a release 11.5 format, due to changes made in release 11.6 in support of new features.
Action:
Can only migrate back to release 11.6.
