Previous Topic: 5560ENext Topic: 5562E
5561E
NEW PASSWORD INVALID OR NOT ALLOWED
Reason:
An attempt to change the current password on the remote system by using the CA XCOM Data Transport change password feature was rejected by the remote system's security software. There are two common reasons for this rejection:
  1. The indicated new password did not conform to the password syntax conventions on that system.
  2. For a user ID that possesses a “multi-password” attribute (that is, different passwords for different facilities), there was no current password defined for the CA XCOM Data Transport facility. Hence, it could not be changed.
Action:
For problem type 1, specify a legitimate new password or postpone changing the old password. For problem type 2, define a password for the CA XCOM Data Transport facility to the remote security software, or remove the multi-password attribute from the user. As an alternative, you might try resubmitting the request without specifying any password.
