Previous Topic: 1010INext Topic: 1013I
1012E
XCOMCFTK TASK HAS ABENDED WITH SXXX
Reason:
The task has abended with abend code SXXX.
Action:
If the reason for the abend is known, correct the problem (for example, module not found). Otherwise, keep the CA XCOM Data Transport log, SYSLOG, and dump and call CA Technical Support.
