Previous Topic: 0851ENext Topic: 0853E
0852E
ENABLE FAILED DUE TO PREVIOUS FAILURE
Reason:
You tried to enable a superlist. This process causes one or more related lists to get enabled separately.
In this case, at least one of the related lists has failed to enable. Therefore the entire superlist has failed to be enabled.
Action:
Check the superlist and related lists, and then try the enable again.
