Previous Topic: 0264ENext Topic: 0266E
0265E
xxxxxxxx MEMBER NOT FOUND IN PDS DATASET
Reason:
CA XCOM Data Transport issued a FIND macro to position itself to the correct member in a partitioned data set, but a “not found” condition was raised. The file transfer is terminated and this message is sent to the conversation partner. This error normally occurs under two circumstances: if an alias exists for a member but the actual member does not exist, or if the partitioned data set has been corrupted.
Action:
If xxxxxxxx member in above message is that of the START=xxxxxxxx in XCOMDFLT or in the PARM statement override, you must define a member whose name matches that of the START= member in XCOMDFLT or in the PARM statement, if used. The member may contain a comment statement only if no destinations are to be enabled during initialization of the CA XCOM Data Transport server. Otherwise, this message displays and no scheduled transfers will be activated.
