Reason:
CA XCOM Data Transport attempted unsuccessfully to dynamically allocate a data set. The message operand xxxx provides the dynamic allocation error codes. The message operand yyyy provides the dynamic allocation information code.
Action:
Check the meanings of these codes. The easiest way to do this is to log on to TSO/ISPF and access the Main Menu of the Program Development facility. Choose option T for Tutorial. Then access the table of contents (in some cases this is done by typing UP). From the table of contents menu choose A for Appendix A. This will display the dynamic allocation codes on the two first pages. Documentation of the reason codes can also be found in the IBM documentation.
