Previous Topic: 0185ENext Topic: 0187E
0186E
zzzzzzzz RC xx FDBK2 yy SENSE nnnn nnnn cccccccc
Reason:
The VTAM LERAD/SYNAD routines were entered with return code xx, feedback 2 code yy, and sense data nnnn nnnn. VTAM command cccccccc caused the error. zzzzzzzz is the LU name.
One of the more common versions of this message is RC 14 FDBK2 4B SENSE 0821 0000 SIMLOGON, which generally indicates that the default mode entry for this APPLID is not in the Logon Mode Table used by this APPLID.
Action:
This is often only an informational message, because many VTAM return codes are normal, for example, indicating a session is not active. Look up the return code and the FDBK2 code in the IBM documentation. If the codes indicate an error condition and this error persists, take a CA XCOM Data Transport trace and contact CA Technical Support.
