Previous Topic: 0148ENext Topic: 0150E
0149E
INVALID HEADER FILE TYPE
Reason:
The first message CA XCOM Data Transport transmits is called the Header Record. Among other things, it identifies the type of file being sent as standard data, a report, or a job. In this case, the file type field that was received by this system from its session partner was invalid.
Action:
The remote user should verify that a proper file type is being specified. Take a CA XCOM Data Transport trace and contact CA Technical Support.
