Previous Topic: 0019ENext Topic: 0023E
0020E
REQUIRED PROGRAM NOT LOADED—XCOM TERMINATING
Reason:
A program that was required by CA XCOM Data Transport was not loaded; execution terminates. Message 0019E will describe the error codes encountered loading the program.
Action:
Resolve the errors associated with loading the program and rerun the job.
0021E
DEFAULT OPTIONS TABLE MUST BE RE-ASSEMBLED. GEN-LEVEL/VERSION (xxxx-xxx) DOES NOT MATCH XCOMXFER (yyyy yyy).
Reason:
The Default Options Table and the version of CA XCOM Data Transport do not match. xxxx-xxx represents the version of CA XCOM Data Transport macro libraries used to assemble the default table. yyyy yyy is the version of the CA XCOM Data Transport server. Both xxxx xxx and yyyy yyy indicate the service pack sequence number within the service pack.
Action:
Reassemble the default options table with the correct macro libraries. For more information, see the CA XCOM Data Transport for z/OS Administration Guide.
