Reason:
CA XCOM Data Transport could not load a required module. In the first message, CA XCOM Data Transport could not load or find XCOMMSGT, the message table. In the second message, CA XCOM Data Transport could not load the module xxxxxxxx.
Action:
Check that the CA XCOM Data Transport loadlib is in the STEPLIB, JOBLIB, or LINKLIST libraries. See the chapter “Installing Your Product” in the Installation Guide. If you are using multiple CA XCOM Data Transport libraries, make sure they all have the same level of APF authorization.
If the later format of the message is displayed, make sure the module xxxxxxxx is in one of the libraries stated above with the same level of authorization, if you are using a combination of STEPLIB, JOBLIB, and LINKLIST.
